Header + catback install cost?
  • Thread starter Thread starter dz187
  • Start date Start date May 3, 2007
dz187
65
Arizona
May 3, 2007
  • May 3, 2007
Mac equal length shorties + mac catback. Dont have the tools, garage, or time to do it myself... so what should I expect this to cost me? Also... the regular bolts that came with the headers had one longer bolt, but the locking bolts that I purchased do not. Could that end up being a problem if I dont use the longer bolt?
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
May 3, 2007
  • May 3, 2007
My locking ones are all the same size and fine.
A shop may quote anywhere between 3-6 hours for a header install, I've heard instances of that full range at different places. They may also quote 2 hours for a catback, although it shouldn't even take an hour for someone with a lift and the right tools. But shops can say it takes as long as they want, ya know?
Anyway, figure that and multiply by whatever the going rate is in your area, 40-80 per hour, and there's an idea.
Or just call up shops in your area and get a direct quote
dz187
65
Arizona
May 4, 2007
  • May 4, 2007
Anyone know some good shops in arizona? Mesa/chandler-ish area
D
Daggar
3,902
  • May 4, 2007
All you really need is like a Meineke shop or any other muffler shop. Go someplace that guarantees their work (meaning don't take it to Bob's Muffler and delicatessen). Get an estimate.
U2SLO450
118
  • May 4, 2007
I say go ahead and give it a shot at home, you don't need a garage, the only tools you need is a socket set (extensions help but not required) spray some pb blaster on the header bolts the night before and they will come right out. The headers drop right in and bolt directly to your factory h-pipe as do catbacks. Even if you've never done it before it'll still take less thatn a day.
dz187
65
Arizona
May 4, 2007
  • May 4, 2007
Well.. i also need a length of pipe fabricated between the H-pipe and mufflers
Ozz
3,514
66
109
Canton, MI
May 5, 2007
  • May 5, 2007
Why, what's wrong w/your H-pipe? For the cost of that you could very well get a used (or even new) H-pipe and just replace the whole system
The hardest part of the job is ****ing with the header bolts and EGR tube fittings, and lining up the H-pipe.
dz187
65
Arizona
May 5, 2007
  • May 5, 2007
Nothing wrong with the H-pipe. I bought the catback used and it didnt have the flow pipes that connect my H pipe to the mufflers... the price was right though
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
5.0 Rebuild
  • smittys7up
  • Nov 29, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Today at 9:11 AM
smittys7up
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Quieter Mufflers for Supercharged 5.0
  • oz
  • Jun 24, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 14, 2024
2000xp8
