  • SN95 4.6L Mustang Tech
headers
  • Thread starter Thread starter 2oo3gt
  • Start date Start date Jan 25, 2006
2oo3gt
65
  • Jan 25, 2006
If i hav acsess to a lift, is it possible to replace the headers that way? Or do i need to pull the engine. I am buying my full exhuast, but don't know if i wanna do headers now b/c of the install. Thanks.
M
Mustanggt108
221
  • Jan 25, 2006
with LT's i think you either have to un-bolt the bottom of your car and install it that way. Or lift your engine just a tiny bit , and you can install it that way as well. With shortie headers , i dont think you'll have a problem with the instal
csledd
Official Ovary Punching Member
1,115
Paducah, KY
Jan 25, 2006
  • Jan 25, 2006
well you definately shouldn't have to take your engine out, just might have to remove your k-member.. me and my dad installled my LT's in our very small 1 car garage without a lift..
yeah that one floor jack is older than me
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jan 25, 2006
  • Jan 25, 2006
I love the bottle jack sitting on the old floor jacks lift pad. I have never seen anybody do that before.
Well anyways back to the topic. you can either jack the motor up or lower the k-member as the pic shows. The motor does not have to come out
csledd
1,115
Paducah, KY
Jan 25, 2006
  • Jan 25, 2006
lol all I have to say about that is desperate times call for desperate measures and we were already frustrated enough because we tried to install them without dropping the k-member
2oo3gt
65
  • Jan 26, 2006
So with the shorties i should be able to do it without dropping the k-member, or do i still need to drop it. Im gonna do it at my friends body shop which he owns, so would a lift make it easier? thanks.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Jan 26, 2006
  • Jan 26, 2006
I installed my header with
2 floorjacks
2 Jackstands
2 Rhino ramps
Various hamd tool
21 cans of MickyLight
2 lg pies of pizza
And no help( need to make friend...)
I guess some people do install them without dropping K member. I personaly don't see how. Some bolts(like that of back of driver side, and top of passengerside) were hard enough with K-member dropped.
Way I see it, any time you save by not dropping K-member is going to be consumed by trying to snake header in, locate 3rd starter bolt, deal with steering shaft and generally too tight of space to do anything.
Here is link I followed when I did mine. almost dead on. I think only thing thats not right was one spot, it says it use 24 mm, where as it should have been 21mm or something like that.
http://www.fnsweet.com/garage/lt_install/index.shtml
MineralG2k2GT
451
Lowell, MA
Jan 26, 2006
  • Jan 26, 2006
dropping the K memeber is def. an option...but its not the only one
Since most LT's dont give you access to the clutch with out taking a LT off, i decided to d a clutch at the same time
with that said, I did no drop the k member but rather took the tranny off and jacked up the motor....
that method worked awesome..and if yo have lift you have a bigger advantage. I would definity recomend doing it that way
mity2
Jul 24, 2003
2,872
StateCollege PA
Jan 26, 2006
  • Jan 26, 2006
i think dropping trans is more of work then dropping K-member. But doing clutch at the same time is not bad idea. My clutch went month after I installed the LT's .....
C
Need MIL Eliminators?
  • crazyone64
  • May 18, 2026
SN95 4.6L Mustang Tech May 21, 2026
GOvert
G
Engine Keeping O2 sensors lit with long tube headers
  • keel
  • Jul 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
Need help ordering a oil cooler and filter relocation kit but don't know what I need
  • Aiden Brown
  • Aug 22, 2026
SN95 4.6L Mustang Tech Sep 14, 2026
squeak93
K
351w engine swap
  • Killer351w
  • Jan 21, 2026
2005 - 2014 S-197 Mustang -General/Talk- Jan 21, 2026
Killer351w
K
C
Engine 01 gt
  • Carboni
  • Jun 28, 2025
SN95 4.6L Mustang Tech Jul 19, 2025
nickyb
