Engine Heads And Cam
94coupe
138
Calgary ab
k so I've pulled the motor out and am gonna do a budget build. I'm gonna stay stock rotating assembly. .30 over.
what pistons should I use, and what hci should I use remember I'm on a budget...but also wanna be able to put a shot of now one day
thanks
the car is an 83gt gonna top it off with Holley demon 700cfm
Carb is a bit big for a street car.
Rule of thumb for street driven cars - multiply cubic inch x 2 and add 0-50 and that is the size carb to use. The 0-50 is the fudge factor depending on what kinds of mods you have. Stock is 0, 50 is hot HCI.
Reactions: 94coupe
Speedpro are decent budget friendly pistons. Get some with valve reliefs in them not the flat tops that came in your motor. For a time tested budget top end, get set of JY explorer heads, swap the springs out with some TFS springs, and throw in a TFS1 cam. Check the message boards and ebay as guys are always selling these heads already upgraded. I also agree, a 600-650 cfm carb is plenty. You could be around 275-280 rwhp with this.
Reactions: 85rkyboby
If it's really a budget build, just buy and explorer engine, swap the cam, change the springs, sell the intake.
Since you aren't going to a stroker, i see no reason to spend a bundle building a shortblock.
