Heads and flycutting
  • Thread starter Thread starter Bad92GT
  • Start date Start date Apr 14, 2009
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Apr 14, 2009
  • Apr 14, 2009
I have a set of heads sitting here at the shop that I'm considering throwing on my car. Albeit they are a little large, I don't see how with a custom grind cam, good matching intake, and a good tune, it couldn't pump out some serious power for a stock shortblock car. I've never had to worry about flycutting or PTV mostly because of aftermarket piston solutions in my motors but since I'd prefer to leave this motor alone, I figured I'd give it a shot. The heads in question are a set of victor Jr 210cc 2.05 intake and I believe 1.6 exhaust valved heads, lightly gasket matched. The only way to make them fit is by flycutting, however I don't have much experience with that and was wondering if anyone here does. Equally the same, I'm questioning whether the amount required to cut out of the piston will be so great that I could either weaken the piston greatly, or unbalance the rotating assembly by removing to much material. These heads are fairly large for the bottom end, and I am partially compelled to scrap the idea because of that. However I don't see how they CAN'T make good power, albeit a little high in the rpm band. I'd appreciate the help.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 14, 2009
  • Apr 14, 2009
The thing about this that i would worry about is, it's not so much the depth of the relief that becomes the issue but more of the width or diameter of the relief due to the 2.02 valve. What i'm getting at is, you're getting pretty damn close to the edge of the piston and that'll weaken it more than going deeper. The other thing i don't like about doing this with the pistons in the engine is that it's very hard to gauge how much you have taken off each piston and you can't balance their weight.
Bad92GT
Jun 10, 2004
492
SC
Apr 14, 2009
  • Apr 14, 2009
exactly. Thats what I've been considering while going over it all. Aftermarket pistons are pretty nice since they all are the same casting but in this case its a little off the cuff'.
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Apr 14, 2009
  • Apr 14, 2009
Personally i can't stand the idea of cutting stock pistons. The way i see it, they were cast/forged with the amount of relief they were intended to have, or in other words they don't have extra material for cutting like most aftermarket pistons do. Personally i wouldn't do it, but a lot of guys do and never have a problem. I'm a chicken when it comes to stuff like this, i don't have the cash to make expensive mistakes.
Engine Heads and how to buy
  • Dontknowchit
  • Aug 16, 2025
2K
Fox 5.0 Mustang Tech Aug 24, 2025
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Nov 3, 2026
Kleinjj27
K
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
