heater core change
  • Thread starter Thread starter teamstream
  • Start date Start date Mar 2, 2007
T
teamstream
  • Mar 2, 2007
anyone have a step my step directions on how to change a heater core in my 90 GT? i know its a pain and i'm thinking of doing it myself.
90blacknight
136
Mar 2, 2007
  • Mar 2, 2007
See the useful technical thread index at top of this forum. It's not hard to change the heater core, just time consuming. Basically you have to remove the center console, drop or move the dash, drop the steering column to access the heater core box in behind on the passenger side. The box which holds the core is held in place by some nuts and bolts, some accessed under the hood. Also you can do a search in the forums, there are plenty of threads on this. Give yourself at least 3 hours (most likely 4 to 5) if you're doing it the first time.
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
  • Mar 2, 2007
First, what year car do you have.. did it come factory with a/c? that will determine how difficult it is. You might end up taking the dash out for something you can do through the glovebox
P
PRO50SC
1,012
Olney, Maryland
Mar 2, 2007
  • Mar 2, 2007
http://www.mustangmonthly.com/howto/5652/
PeteyAce
346
Mar 2, 2007
  • Mar 2, 2007
i just had a thread about me to change my heater core, if you got 87-93 you gotta take the dash apart. anything below that year glove box just needs to be taken apart
D
Daggar
3,902
  • Mar 2, 2007
... unless equipped with A/C. If you have an A/C car, the job sucks no matter what. There was no dash dropping in my 86. The dash had to pretty much come out to get the job done. Even then, the HVAC box had to be cut to get the core out (unless I was willing to also disassemble the whole A/C).
If you're still running R-12, your best bet will be to plan to cut the box open.
Enough blathering from me though... knowing the year of your car makes a significant difference.
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
Install 79-93 Mustang Heater Core Replacement
  • AeroCoupe
  • Oct 13, 2025
  • Resource Discussion Forum
Resource Discussion Forum Oct 17, 2025
85GTStangGuy
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
