  • 1994 - 1995 Specific Tech
Heater Core Woes
  • Thread starter Thread starter StangRider1
  • Start date Start date Nov 27, 2007
StangRider1
45
Vancouver, Washington
Nov 27, 2007
  • Nov 27, 2007
Well, my '95 Mustang GT is once again parked with yet another blown heater core, this is the fifth one to fail. I've had the cooling system flushed several times, installed a Fluidyne radiator, replaced a leaking water pump, yet I continue to have heater cores fail at a rate of about once every two years. Thankfully, Autozone is as good as their word on their lifetime warranteed parts. Just can't figure out what's causing the repeated failures. Does anybody out there in the ether have any hints or suggestions before I install core #6?? Any help would be appreciated. Thanks in advance.
Kerry
9
95oRANGEcRUSH
I dig fat chicks
631
Canton, Ohio
Nov 27, 2007
  • Nov 27, 2007
It sounds like you have done everything you could possibly do.
I'm on #3 myself.
Stanger007
2,015
Baton Rouge, LA
Nov 27, 2007
  • Nov 27, 2007
Guys I hurt for you. My old Fox had a heatercore go out and boy what a pain it was to change.
I bought an Autozone replacement then heard the Ford one was better so I bought the Ford one and compared the two. I went straight back to AutoZone and returned it. The Ford unit was better in all respects to what AutoZone had given me!
Good luck with it!
Wes
BlackPearl955.0
126
Blashyrkh, Wisconsin
Nov 27, 2007
  • Nov 27, 2007
Im on number 2 and got pretty good. I cant imagine how good you are at it
what part is failing? Mine was where the tubes enter the acutall core. I put a thick coating of soder around the base of each tube and it seems to work very well.
go-stang5.0
2,244
Glenview,Il
Nov 27, 2007
  • Nov 27, 2007
I would say go look at a ford one for comparison Wes is probably right. If its easy and quick to replace I don't have a problem getting the cheapo lifetime warrantied parts but something like a heater core I would never want to do again, let alone 6 times .
GTA_V6_Mustang
1,326
Miami, FL
Nov 27, 2007
  • Nov 27, 2007
I actually have a new one siting in my trunk waiting to go in. Just dreading pulling the dash out. How bad is it? Ive done them multiple times on Grand cherokees so I cant imagine it could be worse
94CobraPace
907
Houston, Tx.
Nov 27, 2007
  • Nov 27, 2007
Get the Ford heater core.... I did 5 on a F150, 4 from Autozone and the last from Ford, never had another problem. You can return the broken one to autozone for a refund, I did and they refunded it because I had all the return reciepts showing the 4, plus I had a reciept from a shop and they refunded me that money.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Nov 27, 2007
  • Nov 27, 2007
Well ... just as said above
I've seen many say over the years you wanna use a Genuine Ford hc as they
are just so much better than what you find at local places
Considering how much of a hassle it is to swap em out
This sounds like one of those times you just don't wanna compromise
I know when mine lets go ... I'm gonna go to the Ford house
Grady
Zero_chance
1,244
Maricopa, AZ
Dec 3, 2007
  • Dec 3, 2007
You may need to add a restrictor to limit flow into the heater core. ANd yes, Ford ones usually are better.
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
  • mnky99
  • Sep 5, 2025
mnky99
M
G
2006 Mustang GT o2 Sensor Wiring Issue Car Bogging/Choking
  • GCantero93
  • Sep 5, 2025
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 6, 2025
  • dan50
  • Jul 18, 2026
dan50
180 Thermostat and new coolant leak
  • bn536
  • Dec 9, 2023
  • 2 3
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 5, 2024
from6to8
