heater core :(
  • Thread starter Thread starter ras50gt
  • Start date Start date Feb 28, 2007
ras50gt
200
  • Feb 28, 2007
Well I think my heater core is going bad. What sucks is I randomly saw a thread about this not too long ago and now all of a sudden its happening to me.... I noticed in the last week or so that it would take a really long time to defrost the front windshield. I then checked under the dash on the passenger side to find a small stream of fluid coming down. I still get heat from the vents and it will eventually clear the windsheild but not like it use to. Plus I also noticed the radiator fluid going down every once in awhile. I only use the heater for the defroster when the windshield is fogged up. Anways, I'm sure there are threads on this but I want to get all the help I can on this as I will probably be taking on the heater core task soon.
I want to know what tips you guys have, whats the best way to do this job. I remember reading somewhere that you can just prop the dash and don't have to disconnect the gauges and speedo?
Also, anyone get a heater core from 50resto.com? Where is a good place to get a heater core? I remember seeing something about a restrictor, does the new heater core come with that?(one from 50resto.com) Can i buy that? Also, do I need to reseal something? what do i use to do that? Thanks!
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Feb 28, 2007
  • Feb 28, 2007
From the sticky at the top of this forum...
86bluecobra
Advanced Member
Dec 20, 2004
4,265
12
69
B.C. Canada
Feb 28, 2007
  • Feb 28, 2007
If you are a non A/C car it is a really easy task. Just remove glove box and undo a few bolts on the heater core cover and remove it. Of course the hoses have to be taken off. I think there is a vent control or fan control that has to be taken apart aswell just a wire that unsnapps off its clip.
M
Mike85000
65
  • Feb 28, 2007
Careful, my car was non-AC (from the factory) but when i got my core, it was the wrong one. Inlets were centered. Turned out i needed an AC version with the outlets off to one side for my original non AC car.
Don't know what ford was thinking..
V
v8only
2,378
22
49
Mar 1, 2007
  • Mar 1, 2007
that's some SERIOUSLY mickey mouse ****, do it right, don't cut the damn box, here is my tech article, IMO, the best on the net..
Hey guys, I finally changed out my heater core this weekend, as per all of your suggestions. Looks like my old core after all was beginning to show signs of leaking. Hopefully next weekend my dash will go in. I'm going to start this article with the dash removed for simplicity sake. This is a very detailed step by step procedure with NO cutting involved. Evacuating the a/c is also not required. This was also performed on an 86 gt vert, though it applies to almost all year foxes.
TOOLS and supplies NEEDED:
-7/16 socket, preferably long socket, short extension and ratchet
-7/16 wrench
-5/16 short wrench
-5/16 socket and ratchet, preferably long
-Black RTV
-phillips screwdriver for door sill and kick panel removal
-3 to 3 1/2 inch socket to jam between dash and firewall for clearance
-Beer
1. Remove dash, or unbolt and lower out of your way.
2. A. Remove the nuts on the firewall on either side of the air conditiong accumulator. For this I used a 7/16 deep socket and short extension on both sides. Pull the bracket back on each side. Don’t be afraid to pry and bend the bracket back and away from the firewall, it won’t break, and it’ll bend right back on.
B. Now remove the nuts that were behind the bracket. I used the same 7/16 setup from before on the right side, and a 7/16 wrench on the one closest to the passenger side.
C. While you are there, take off the heater hoses going into the firewall and spray the heater core outlets with a white lithium grease so they will be lubricated enough to slip off the rubber grommet.
3. Pull the carpet back slightly on the passenger side. This is important for several reasons. The first is that coolant may spill on your carpet. The second is to gain access to the bottom housing nut seen in the following picture.
4. using a 7/16th socket, remove the very bottom housing bolt shown in the above picture and the top two housing bolts shown in the following picture.
5. Grab on the entire box and pulling it towards you, wiggle it out a few inches. When it’s out far enough the heater core outlets and studs will be on the inside of the firewall as shown in the following picture. Do not attempt to pull the whole unit out, it will not come out all the way with the air condition condenser still installed. The goal is to just pull it out just far enough to gain access to access the bolts on the top of the heater core lid.
6. Jam a socket between 3 and 4 inches long between the top of the heater core lid and the top of the firewall as shown in the picture. This is essential or you will not have any room to access the back bolts.
7. using a 5/16th deep or 8mm (it is possible to use a short socket but it’s more difficult) undo the front two heater core lid bolts. Now use a very short 5/16th wrench to undo the driver side rear bolt. Now use the deep 5/16th with the small ratchet to undo the passenger side rear bolt. Please keep in mind that these two rear bolts are a pain in the butt to remove, take your time and do not drop the bolts behind the back of the heater core box. Additional tip is that if you do not have enough room to pull the rear two bolts off, you can remove that plastic insulation that goes along the top of the firewall/frame.
front two bolts
rear passenger side bolt
8. Remove the heater core see picture. Be careful not to spill coolant.
9. Remove all of the old black silicone from the inside of the heater core box. Make sure all of it has been removed, this is critical
10. Put a bead of silicon(I used the black rtv) around the edge of the inside of the heater core box where the new heater core will rest, as show in the following picture. Lubricate the new heater cores outlets.
11. Slide the core in while a friend makes sure that the outlets slip through the rubber grommets at the firewall. The rubber grommet does not go through the firewall, it stays on the inside.
12. The heater core is now seated properly as you can see in the next picture. Bolt the lide back onto the heater core box. The passenger side rear bolt is not essential if you are having trouble putting it back on.
13. Pull the socket that’s jammed in there out. Push the box through the firewall with a friends help from the other side to watch. DO NOT TUG ON THE HEATER CORE OUTLETS.
14. Put the three nuts back onto the housing and put the nuts back onto the studs coming through the firewall. Bend your brackets back, put your final two nuts on.
15. Reinstall dash.
90blacknight
136
Mar 1, 2007
  • Mar 1, 2007
I've had this happen as well. Ordered the non-A/C version prior to disassembly and found out I need the A/C one, and the car never had A/C.
Engine Bleeding air in the heater core
  • keel
  • Apr 2, 2026
Fox 5.0 Mustang Tech Apr 23, 2026
limp
Engine Heater hose restrictor purpose
  • Mcmahst
  • May 5, 2025
Fox 5.0 Mustang Tech May 11, 2025
limp
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
Install 79-93 Mustang Heater Core Replacement
  • AeroCoupe
  • Oct 13, 2025
  • Resource Discussion Forum
Resource Discussion Forum Oct 17, 2025
85GTStangGuy
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
