Help a stanger out
lmFAO at your avatar Rs. :nice:
On topic:
Why dont you try tech? 5.0 talk can be informative, but usually it an area for members to hang out, be retards and have fun. The serious side of things is in 5.0 Tech. If you've decided on the heads and the intake, get a custom grind cam, ask them what size rockers to use in correlation with your setup, etc. etc.
87Mustang351 said:
ill buy slicks over the winter, but jsut with slicks i wont be low 12's high 11s like i had said do u think afr185s 2.02/1.60 and a eldbrock rpm performer air gap is good setup tho?
air gap is a nice intake. not too expensive either. what kind of carb do you have now? fuel pump? holley blue pump and regulator, and a good double pumper carb is a must. i cheaped out and got a 600cfm edelbrock for my 347 when i built it, didnt last long so i replaced it with a 600 small bowl holley, and kept draining it bowls at the track...so i got a blue pump and a 650dp and havent had any probs since. those heads are mean, jump for those if u want aluminum. the windsor jr irons are nice too.
