E ERS SuperStang New Member Mar 12, 2019 2 0 0 Salem,Indiana Mar 12, 2019 #1 Mar 12, 2019 #1 Anyone know why my car won’t start an is flashing “Theft” after my battery went down an wont read my X4 SCT TUNER. appreciate any help I can get.
wmburns SN Certified Technician Aug 14, 2009 5,892 514 204 Houston Texas Mar 12, 2019 #2 Mar 12, 2019 #2 Yes. After you have visually checked out all of the fuses, Check out: 1996+ Crank with no start check list https://www.allfordmustangs.com/forums/4-6l-tech/336452-1997-mustang-wont-ignite.html#2984838 Pay close attention to the part about the PCM/CCRM ground wire that goes around the battery to the radiator core support.
A AutodesignJohn Member Mar 21, 2019 40 4 18 Long Island Mar 21, 2019 #3 Mar 21, 2019 #3 It's the PATS system. It's not reading the key correctly. Could be some error, try using forscan or a similar program to check what the PATS is reading.
