Help- GT going 13" Rotors
So did you use the stock calipers in the back with a bigger rotor? Which rotor did you go with? Stock size?
2000BLKGT said:
Baer Eratadspeed rotors here, with Mach 1 calipers, Hawk pads and SS lines (wanted black calipers).
You can use the stock GT calipers on the rear...but the fronts have to be swapped.
Wikkdgt said:
You can't run a 13" rotor with the stock GT calipers because I think that they are thicker than the stock rotors. I could be wrong on this though.
Not to mention the curvature of the caliper is totally different. You need to use Cobra calipers with the 13" rotor. As you can see, the GT caliper wouldn't cover the entire rotor.
Yes...stock GT calipers with the Baer eratispeed rear rotors...same size as the cobra rear rotors (11.5" I think). But I had to buy a FRPP kit with new brakets etc. (fuggin kit comes with way too much...even includes a stock set of rear FRPP cobra rotors...so I just sold the FRPP rotors)
My wheels are 17 x 8 up front, and we had to add a 7/16" drop in wheel spacer to clear the new brakes...so we swapped in longer ARP studs to compensate for the extra distance.
No clearance issues with my rear wheels (17 x 9.5 in the rear)...but we added a set of 1" hubcentric spacers...so the rear wheels sit where they should now.
