Engine Help hard/no start runs rough.
  • Thread starter Thread starter Mr.Kelley
  • Start date Start date Dec 24, 2023
  • 3
First Prev 3 of 3
Mr.Kelley
194
117
53
San Diego Ca
May 18, 2024
#41
  • May 18, 2024
  • #41
@GK It has the racecar setup. Master kill on the rear panel, Trunk mounted battery, 1 ott welding cable running to the engine bay, lighted Ignition switch, starter button, CEL. where the radio was.
I drove it to work this am, ran fine once started. Got here shut off, immediately try to restart, no luck. Wait 30 sec, still no. Wait an hour, temp gauge at 100* fired up fine several times. Let run 5 min won't start. Shot of either fires right up.
Mr.Kelley
194
117
53
San Diego Ca
May 18, 2024
#42
  • May 18, 2024
  • #42
I'm setting up my DVOM so I can monitor voltage at different components one at a time. I figured I'd start at the coil +, then injector(s). Fuel pump I can hear prime and stop after couple seconds and I do have 38# when ignition is turned on, pressure does not bleed off after shutting off.
Mr.Kelley
194
117
53
San Diego Ca
May 18, 2024
#43
  • May 18, 2024
  • #43
I think I found an issue. Checking voltage on coil + switch on engine off 10.5-11.0. Start cranking volts drop to 5-6. If I see 7 or more volts at the coil while cranking it will fire. Below 7 nada.
Running voltage at coil + 12
Battery voltage measured at solenoid is 12.6 engine off 13.7 running
Thoughts?
Mr.Kelley
194
117
53
San Diego Ca
May 18, 2024
#44
  • May 18, 2024
  • #44
Bad solenoid. I am getting 5-9 volts on the "I" terminal at the starter solenoid while cranking.
manicmechanic007
5 Year Member
Sep 26, 2017
2,562
727
143
Roy, Utah
May 19, 2024
#45
  • May 19, 2024
  • #45
You are on to it
Try temporarily hot wiring straight to 12 volts as a test
  • 3
First Prev 3 of 3
K
88 speed density misfire and bucking
  • kush
  • May 29, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
DadLife0724
Engine Surging idle on start-up
  • keel
  • Aug 11, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
keel
G
Idle surging after warm up
  • GALLY3309
  • Jun 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 10, 2026
  • dan50
  • Jul 18, 2026
dan50
  • brandyn200
  • Jun 20, 2026
AeroCoupe
