HELP! HOW TO MAKE CEL FLASH?
97SVTsnail
40
I just put in a B cam, explorer intake/70mm TB and longtubes on my 95 GTS, the car runs ok but is sorta skipping, not like a dead skip, just sorta sputters lightly like it's flooding a bit. I checked the plugs, they are good, same distributor, coil and wires as before. I need to know which wires to jump in the EEC test post to make the CEL flash codes. Any advice on the culprit appreciated too!
I have changed and checked everything, plugs wires MAF TPS, etc.. The only thing I can think of is maybe I got the cam a tooth off??? Or maybe a bad lifter?? What would the symptoms be if the cam were a tooth off?
It seem slike I am getting no fuel on #6. plug is getting fir fir sure but it is not wet at all, no sighns of that cylinder burning, after 10 miles plug still looks brand new, what could cause this? I check the injector wire, it is plugged in.
Did you run a cylinder balance test as part of the code retrieval process?
If it fails on number 6, put a noid light across the #6 injector and see if the light pulses. The injector gets accessory 12 volts and the ground is modulated to energize the injector.
Good luck.
Thanks guys! I Did infact crack #6 plug but I replaced it, all others look good, wires look good, May change them just for the heck of it. I will try the light on the injectors and see what I come up with there. What is a cylinder balance test??
