Friend is out of town, for a week, so I got permission to use his shop to fix my posi that so badly needs it. Threw the FMS posi rebuild clutches into a little pan of friction modifier, got my car up on jackstands, pulled the diff cover, removed the brakes & axles, go to pull out the 's' spring, and find that there is no 's' spring........instead there are a couple plates sandwiching little coil springs.......I know this can't be the factory posi, because when looking for the little tabs clutch tabs that should be visible in the sides of the carrier, there aren't any
Most people wouldn't be angered to find that they have an upgraded posi, but I now am stuck with a partially disassembled car with an unknown brand of posi, and the uncertainty of whether or not I can rebuild this thing. Any surefire ways to identify it? From looking at pictures on summitracing.com, I think it might be an eaton, but I have no way of knowing for sure. Can anyone give me some direction as to how I can go about figuring this out? If it is an eaton, will I be able to rebuild it, or will I need to cough up the change for a whole new unit?
