ok, to make a long story short, i have a t-5 and it has no i.d tag, just casting numbers. i'm pretty sure it's a v-8 trans but i gotta be sure for my own sanity. is there an easy way with out opening this thing up and counting gear teeth to determine if it's a v-8 trans?
can i put it in first and rotate the out put shaft once and see how many times the in-put shaft spins?? i don't have the pilot beating yet.....is there a certain diameter the snout on the input shaft measures??
also, down the road i may get curious and open it just to check it out inside, is there anything obviouse i should look for?? it's supposed to be rebuild with 15,000 on it but, you know how that goes.......
any info appreciated..
