help iding
Noting the DS rotations to one wheel revolution is the only way to know - we dont get new tags when we swap gears.
The door tag should also have the axle code on it.
Good luck.
im hoping i have and 8.8 in the car casue i decoded the vin today and its a 1980 4cycl car but the owner b4 me converted it to a v-8 can and made it look like a 87 up car so im hoping he swapped out the rear too. about the rotation thing how dose that work?
I put a piece of masking tape on the bottom of the tire (it does not matter where you put it - the bottom is easy for me to see and remember) and I put a marker line on a spot on the DS.
Then, with the rear jacked up, rotate the wheel and count the number of times the DS turns for one wheel revolution. If it rotates ~2.75 times, that = 2.73's, if it rotates ~3 1/2 turns, that = 3.55's, etc.
Good luck.
if you're looking for the type of rear, just look at the cover on the back, if it's square, it's an 8.8, if it's flat on top and bottom, and rounded on the sides, you have a 7.5...
add'l info: the first couple of years of fox bodies also had a 6.75" rear that occupied the four poppers...it's also a square cover, but, I'm betting you'd be able to figure out whether or not you have that rear-it's tiny...
