OrLackThereof
Running 18 to 20 degrees of timing on PUMP GAS with aluminum heads is rubbish.
You're gonna need to run either some 100 or 110 octane race fuel to run that much base advance, unless your engine's compression is....nonexistent.
16 degrees is a good number as long as you dont ping. Ive got Edelbrock alum. heads, and on 93 octane if I run 15 or 16 degrees, I start to ping. And my compression ratio is only somewhere between 9.0 and 9.5:1...probably like 9.4.
You CAN bump the fuel pressure at the AFPR....it's the easiest way to do it. The problem with that is, it bumps fuel pressure ALL THE TIME. Not just in the rpm range you need it...which is why getting a custom chip is FAR better. He's probably saying adding more fuel would make it worse, because you're in a good range in the high rpm zone, which is what you're shooting for in a dyno. So by bumping the pressure to compensate for a low rpm lean condition, you're going to richen the mixture in all the other ranges, and possibly loose peak horsepower.
42 psi sounds about right for your car....that's what I'm running right now even. I tried 45 and it ran rich. 40, and it ran lean...42 was the best compromise I could find. I'm not running a custom chip either.
As far as your 300 hp goal...what everyone else said will definitely help. Also, how's your clutch? A slipping clutch will make you lose some power real bad. I mention this because I'm running an automatic trans ( yes, ENTIRELY different), but Im only expecting to put down 270-280 rwhp right now...but thats because my transmission is slipping BADLY. The motor should be capable of a LOT more.... So that's just something to consider as well.
16 degrees is a good number as long as you dont ping. Ive got Edelbrock alum. heads, and on 93 octane if I run 15 or 16 degrees, I start to ping. And my compression ratio is only somewhere between 9.0 and 9.5:1...probably like 9.4.You CAN bump the fuel pressure at the AFPR....it's the easiest way to do it. The problem with that is, it bumps fuel pressure ALL THE TIME. Not just in the rpm range you need it...which is why getting a custom chip is FAR better. He's probably saying adding more fuel would make it worse, because you're in a good range in the high rpm zone, which is what you're shooting for in a dyno. So by bumping the pressure to compensate for a low rpm lean condition, you're going to richen the mixture in all the other ranges, and possibly loose peak horsepower.
