As you can see in the sig I am at 279RWHP would like 300 on motor alone. I don't have an electric fan yet, but the car runs so cool with the 3 row radiator and the 180* stat that i can't complain there. Even after back to back passes at the track it ran cool. I also plan on bumping the timing from 16* to 17* not that it will make a huge difference but every little bit helps. I want to keep what i have on the car now HCI. I am going to get 1.7rr or 1.72rr and someone said that is worth 10hp? I most likely will pull the AC for weight loss. I don't want to change the 30's to 24's because of one day going SC. WHich leads me to head work. What could/should i get done with the heads? Should i do anything with the intake, however i do like the torque the Cobra produces. I appreciate any advice you guys could give.
thanks
kev
thanks
kev
