I did a search on another forum and it seems like the Tweecer is hard to tune and it cant log boost, while the PMS is easier, but it cant do a lot of things the tweecer can but it can log boost, and I havent read much about Accel's DFI system.
I know a lot of people on here are running the tweecer so I know its tried and true, and a few people just got the PMS, but I havent seen anyone running the DFI. Tweecer people, what do you like about it, what you hate about it, what you can do? PMS people, same for you. And if theres anyone running the DFI setup, please inform me of what you like about it, what it can do, what you hate about it, etc.
Heres some info I got about the Tweecer and PMS
I'm leaning more towards the PMS because you tune it using the little pad that comes with it, but then again, there are very few people that I know running it so I'm leaning more towards the Tweecer R/T.... this is a pain in the ass deciding on which one I should get.
PMS allows you to set timing and fuel curves vs. boost. There are no boost functions on tweecer because you work with existing tables and mustangs didnt come w/boost. This feature would be nice, but I've tuned my car fine w/out it.
I've run The Crane Interceptor II (now known as the PMS), DFI (gen 6), TwEECer, TwEECer RT, and TEC^3. For the money and the capabilities the base TwEECer blows away the PMS, and the RT doesn't even compare. The PMS is overpriced old technology
Tweecer RT allows you to change all the comp parameters, such as turn off EGR, smog pump, change idle, injectors size, MAF transfer, fans. I'm pretty sure you can't do alot of this stuff with PMS.
I dont know and thats why I'm trying to find out which one will be the best. I'd like to be able to change just about anything that I'd want to with it.
So, which would be the best? It seems I know the answer by what I'm saying here. It's really not THAT clear, though. If I get a twEECer, I'll probably just download someone elses files and leave it alone. Is it worth that? TIA. Rob
