Help me find vaccum leak intake noise !
89lxcoupe
207
harlan,ky
i just put rebuilt 289 heads that have been ported with 1.90 1.60 valves on my stock motor with a trickflow r series intake,professional products 75mm throttle body and egr plate and i have this loud whistleing sound that sounds like it is coming from the middle of the intake manifold i've changed the lower intake gaskets again with no luck i have rechecked every fitting and throttle body gaskets, i've sprayed starting fluid over every inch of the intake and throttlebody and injectors. i just can't figure it out. any help would be appreciated........ thanks :bang:
That sounds like the throttle body. Usually the larger you go with the throttle body the louder the wistle. I personally had a 70mm and it was loud but another friend of mine had a 75 and it was twice as loud as mine. Have you driven the car around to see if it does it cruising around?
If you want to: you can seal off all vac ports on the plenum and intake. Leave one port available for your vac tester to connect to. Disable the ignition/fuel system and crank the motor over. You should see 3-9" hg on the gauge. Less than that and you have an issue.
Good luck.
to find vacuum leaks i get a tiger torch and i run the propane over the area's you could have a leak while the engine is running. if you hear the idle rpm pick up whill you run the propane over the engine you have found your leak.
