Help me with a bolt shopping list
I need to get some bolts for my car:
I need to find longer bolts for the lower intake, or 4 studs I can use at the corners to ease alignment when dropping it on the block/heads
Also need to find longer bolts for the cobra upper to lower, I'm using a spacer but I am not getting enough thread engagement with it.
the upper alternator bolt snapped and I don't have its size
some oil pan bolts are missing
and valve cover bolts.
Where would I find this stuff, I don't know where to find good bolts, hadn't really searched online because I don't have the sizes for these various bolts.
I would head to a salvage yard and head for any Explorer or a 5.0 in the motor pile and have at it....:D
I ran the 93 Cobra with a 1/2" spacer and made my own....Most hardware stores sell threaded Ready-Rod in 3' lenghts and you can just cut em to lenght...
The studs for the lower need be like 2" Allen studs, any hardware store will have them..grab a few bolts and hit the stores...
jus take the bolts and go to a reputable hardware store that has a good selection of bolts. Use grade 8 bolts or equivelent. I had to do this several times. I actually stripped out a front intake bolt. the one by the water neck. And i messed it up when i tried to drill it and retap it. So i jus found a longer bolt and it all the way through the head and attatched a nut at the end. works better than anything iv ever rigged.
When talking lower intake bolts .............
Some go through water jackets ... so ... You wanna get STRONG bolts :Word:
They can get all gunked-up at times :bang:
and
You don't wanna have a cheap bolt snap on you if they do :nono:
Clean out the threads good with a thread chaser or tap :nice:
and
Use anti-seize on the threads to help prevent the corrosion ;)
btw ... ANYTIME you put a steel bolt in an Aluminum bolt hole ...
Use Anti-seize :)
A simple way to check length of bolt needed is to stick a small
screw driver or nail down the hole and mark it. Simply measure
the distance between the end and the mark. Don't forget to
allow for bottoming out the bolt :D
Use some all thread or a longer bolt with the head cut off on each
corner to guide the lower down nice and straight when you do
the reinstall.
You will have to run the bolts 3 to 5 times to obtain even torque
readings. Don't forgot to run all bolts one final time after two
heat cycles as they will most certainly be a bit loose.
Grady
