Many of you know that I have been developing a disc brake spindle for use on classic Mustang. The spindle is base on the Granada design. This design is best suited for use on 67-73 Mustangs because the steering arm geometry of 67-73 is a bit different than 65-66. This is of particular note in performance applications. See my last thread for pictures.
Well I've ordered the first production run of the first model and now I'm working on a 65-66 specific model. This model will still be Granada based, but will have steering arm geometry appropriate to 65-66. I would appreciate your opinion as to which outer tie rod mounting stud hole to use. Should I have the steering arms bored to accept the taper of the original tie rod stud, or the larger one from Granada?
The issues as I understand them are that using the original taper allows the installer to use or reuse the originals. The Granada taper would necessitate replacing with the Granada type tie rods, but they are fairly inexpensive and much beefier. The drawback to the Granada is in power steering applications were a bushing must be used on one side along with the original type tie rod or a special high priced tie rod could be used.
What's your opinion? What would you rather use? Why?
