I got a '89 5.0 auto that failed HC & NOx. The NOx might be from not turning on the fan and the combustion chamber running to hot +2500F!!
I bought the car from a tow yard and haven't found out all the mods the guy before me did. My timing was advanced when I went in (around 12degree's) and I didn't drive far to the smog spot so my catalytic converter was probably not hot enough. I retarded my timming to 8 degrees and plan to run her on the freeway and get the cat red hot before going again. + Im turning on the fan
Any other ideas on helping her pass.
Does putting one of those fuel additives or something in the tank help when passing smog tests.
Oh yeah, Im in California!!
Or if anyone knows of any old posts that I couldn't find..let me know.
Also, the timming marks below the pulley doesn't read correctly. When I did my timming it read 0 , 1, 2 ,3 with marks between each number.
I guess 1 was like 10 because below that the engine would die and above it the engine would advance. does anyone else seem to show this???? I think its fine since the engine is running fine but I just wanted to ask.
Thanks for any and all help
