I am installing the Autometer 7001 Gauge Cluster in my 02 GT. I followed the instructions to the letter including disconnecting the neg batt terminal. The install was rather easy. The problem is when I turned the ignition to "on" all gauges went ot their normal position except the tach. It went to the pin at 8000RPM. Turning it off it backs off the pin and points to 8000. I tried starting it and it did not make a difference.
Any clues before I take it all apart and put the stock cluster back in? Thanks in advance for your help.
BMurphy
BMurphy
