Help Quick - Tailshaft bushing
  • Thread starter Thread starter Cobra1894
  • Start date Start date Aug 1, 2005
Cobra1894
196
Broken Arrow, OK
Aug 1, 2005
  • Aug 1, 2005
How do i remove my old tailshaft bushing? Im in the middle of replacing the seal and bushing and I cannot get the bushing out. What do I need to do?
At1Maverick69
220
San Leandro, Cali
Aug 1, 2005
  • Aug 1, 2005
when I did mine, I had to used a special puller to take it out, it kinda looks like a long 90 degree pick and has a night stick like handle that u tap with a hammer. worked for me.
Cobra1894
196
Broken Arrow, OK
Aug 2, 2005
  • Aug 2, 2005
Did you get the puller from a parts store?
Cobra1894
196
Broken Arrow, OK
Aug 2, 2005
  • Aug 2, 2005
Do I need to pull the tailshaft out to get the bushing out or will the tool do it for me? If I do need to pull the tailshaft what do I need to what for?
M
Mark89coupe
206
  • Aug 2, 2005
I went through the same thing a few months back. I just opted to get a rebuilt tranny. It was easier than pulling the tail shaft and other crap.
J
JB66
565
New York
Aug 2, 2005
  • Aug 2, 2005
If you can't rent or borrow the correct puller, you can support the tranny under the bottom of the case and pull the tailshaft housing off carefully, then slip it back on without disturbing anything else.
BERT306
75
  • Aug 2, 2005
except the shifting rail goes into the tailhousing, then you'd have to beat out the roll pin along with removing the shifter and then you'd have alot of fun if your tranny was still in the car.......good luck.....
I have alway beat the bushing out with the housing off the tranny since i didn't think it was possible to be pulled out the end where the seal sits
J
JB66
565
New York
Aug 3, 2005
  • Aug 3, 2005
True Bert, I forgot about that one.
Cobra1894
196
Broken Arrow, OK
Aug 3, 2005
  • Aug 3, 2005
Not what I wanted to hear, I am going to try just a new seal first, if that does not do it then I'm only out a few bucks and will try again later.
maverick0716
3,924
Chilliwack, BC, Canada
Aug 3, 2005
#10
  • Aug 3, 2005
  • #10
I also needed to replace my tailshaft bushing while I was doing my heads and cam swap. I heard you needed the tool and I sure as hell didn't have one so I just took the tranny to a tranny shop and they charged me like $20 bucks including the bushing....pretty cheap and it's better than me messing with it not knowing what the hell I'm doing
Cobra1894
196
Broken Arrow, OK
Aug 4, 2005
#11
  • Aug 4, 2005
  • #11
I might jsut take it to a shop and have it done... Thanks, if its only $20 or so bucks I cant loose.
Drivetrain Tail Shaft bore odd shape
  • R82148V
  • Jun 12, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
Mustang5L5
C
93 Tubular A Arm Bushings
  • Chrispy62
  • Jul 30, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jul 31, 2026
Chrispy62
C
M
Drivetrain T5 Transmission Leak at Tailshaft
  • MDrisc
  • Jun 17, 2025
Fox 5.0 Mustang Tech Jun 18, 2025
AeroCoupe
Suspension Harsh Ride
  • PonyGTrider
  • Mar 20, 2026
  • 2 3 4
2K
Fox 5.0 Mustang Tech Apr 11, 2026
Drivetrain Sticky clutch pedal
  • keel
  • Jul 31, 2025
Fox 5.0 Mustang Tech Oct 17, 2025
Mindseye007
