nos707 New Member Sep 25, 2005 108 0 0 UK Feb 21, 2007 #1 Feb 21, 2007 #1 Are the Non WC and WC T5 cases the same?? Am I right in saying its just the internals that are different? What is a good upgrade part for a stock WC T5?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,271 17,959 224 Massachusetts Feb 21, 2007 #2 Feb 21, 2007 #2 Yes cases are physically the same. The front bearing cup is different so if you use a non-WC case you'll need to swap the bearing cup from a WC trans in it's place
nos707 New Member Sep 25, 2005 108 0 0 UK Feb 22, 2007 #3 Feb 22, 2007 #3 So I will have no trouble swapping all the internals from a WC into a Non WC case?
C C6AE Member Mar 22, 2004 145 1 17 Ma. Feb 22, 2007 #4 Feb 22, 2007 #4 There are a couple little differences in the WC/NWC cases, I don't know if it will hamper your plan or not. Why not just use a 4cyl WC case?
nos707 New Member Sep 25, 2005 108 0 0 UK Feb 22, 2007 #5 Feb 22, 2007 #5 Are 4 cyl T5 cases the same then? Like the cosworth in the UK?
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,271 17,959 224 Massachusetts Feb 22, 2007 #6 Feb 22, 2007 #6 I don't know if the Cosworth has the same T-5. 4-cyl Mustang T-5's are identical though other than a different gearset. I am currently converting a 4-banger T-5 over to a 2.95 Z-spec t-5
