Help w/ Tire Size
  • Thread starter Thread starter wido78
  • Start date Start date Jun 28, 2005
W
wido78
217
Olathe, Ks
Jun 28, 2005
  • Jun 28, 2005
I have a '90 Nocthback that is currently making around 470-480 RWHP / 500 Ft/Lb with a 5-Speed and 3.73 Rear End. I am curious how big of a tire I can run without bogging the car and or rubbing. I currently (at MT suggestion) have 26x8.5 ET Drags installed, but am having fairly significant traction problems off of the line as well as the 1-2 shift.
I am sure that my driving is part of the problem, but I am currently running 11 PSI and launching at 4500 RPMs. I am only cutting a 1.6 - 1.7 60' and then spinning a little in 2nd. I am hoping that someone could help me with tire selection.
Thanks
StangFireman
2,113
Lebanon, Pennsylvania
Jun 28, 2005
  • Jun 28, 2005
Are you wanting to run a slick or a street type tire? Can you tell us your times and MPH? Do you think you want to lower the gear or just a bigger foot print? How wide a rim do you use or want to use?
I currently run a 15X9 with 5.5BS and a BFG drag radial 275/60-15 and have had 1.61 60ft times. But I run a 4.30 and alot less hp and torque.
The 275/60 is 28" tall and a 275/50 would be 26".
T
tjm73
2,418
Rush, NY
Jun 28, 2005
  • Jun 28, 2005
Thanks
I would suspect the tires are more than sufficent and that you should be looking at the chassis setup.
StangFireman
2,113
Jun 28, 2005
  • Jun 28, 2005
Very good point.
W
wido78
217
Olathe, Ks
Jun 29, 2005
  • Jun 29, 2005
What type of items should I be looking at?
I really don't know anything in regards to tweaking the suspension/chassis setup. I haven't added anything to the rear end since I bought the car from a guy in Texas. I do know that the car has Adj Control Arms, Drag Springs, 90/10 Struts?, Welded 8-Pt Roll Bar and ???
As for the type of tire that I would like to run, I would like to stay on a slick and I am running 11.0x at 125 - 127 MPH. It is my opinion that if I can get the car to hook, I should be able to go 10.8x?
W
wido78
217
Olathe, Ks
Jul 1, 2005
  • Jul 1, 2005
Bump...
Any ideas?
87MustangGT5.0
153
Maryland
Jul 1, 2005
  • Jul 1, 2005
Do you still have your front sway bar up in there?
W
wido78
217
Olathe, Ks
Jul 1, 2005
  • Jul 1, 2005
Already gone.
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
7K
Other Auto Tech Jul 28, 2024
manicmechanic007
D
Need help with suspension, wheel + tire size, 91 Fox SN95 5 Lug
  • DHatton
  • Jun 9, 2022
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 9, 2022
nickyb
Tire Fitment, With Pictures. Post your 10.5 wheel/tire combos
  • 89GTRound2
  • Mar 17, 2021
9K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 15, 2024
ThinBlue502
H
'86 New Turbo Build First Start/Idle Trouble. Full Tune specs attached
  • Heffay
  • Jul 10, 2022
  • Digital Self-tuning Forum
3K
Digital Self-tuning Forum Jul 12, 2022
Heffay
H
