Help with 130Amp Alt. & Underdrive pullies!!
gooch06
117
I'm looking to upgrade my 1990 LX 5.0 alternator to a 130 AMP. Can I use my Ford Motorsport Underdrive pullies with the 130AMP Alternator? What will it do if I put back on my stock Alternator pulley?
Myke86GT said:
The pulley off the stock alt won't fit the 3G alt. Running the stockalt pulley with the other 2 UD pullies won't have any effect. Or atleast any you will notice..
It will if you use a washer as a Spacer. I used a off-the-shelf washer from Home Depot as a spacer to run the stock 2G alt pulley on my 3G at.
I've since upgraded to an ASP 1 7/8" pulley. I run March Underdrives with the ASP pulley and have a full charge at idle even with an SN95 electric fan and a decent stereo
Did you need the washer as a spacer with the ASP OD alternator pulley also?
What year is your 3g alt?
ASP told me awhile back that their 1-7/8" OD alt pulley would fit 3g`s up to 1995 because Ford used the same offset spacing as the 2g to that point.Beyond 1995,they weren`t sure,but said it should fit following years.
I just left the pulley that came on my pa-performance 130 amp with my other UD pullies and it charges just fine. I am not sure if you would notice too much of a difference either way.
Kevin
I just left the one that came with the Alt. just to be sure that I didn't have any charging issues(whole reason i switched). I guess I can change it now but I like where my voltage is so it works better for me.
Kevin
No, i am not using a washer with the ASP pulley.
My Alt is a parts store alt specified for a '95 GT. It fits fine with plenty of room
The stock pulley on the all 3 of the 3g alts that I have done are the exact same size as what was in the underdrive kit.
I used the pulley from my underdrive kit (polished) on one of them with no spacer and it fit just fine.
