Need Some help to deciper the following codes:
I get the Following Fault Codes For Sensors ( I tested it with getting engine to running Temp so I believe this what causes these codes)
CODES: 116 - Engine coolant temperature higher or lower than expected
636 - Transmission Oil Temperature higher or lower than expected
NOW CODE STORE IN MEMORY
CODE : 172 HEGO (HO2S) sensor fault/lean
What does this mean?
Here are my symptons:
When cold it trembles a bit, idle not smooth
After it warms up ~ 5 to 10 mins engine runs smooth.
Durring the cold start when I accerate egine bogs a bit, like it can't breathe.
Something weird that never happen is I see water exiting my exhaust pipes.
I also notice my high pressure line to fuel rail was comming loose so I re tighten it.
Any Help much appreciated.
