tvmango New Member Oct 27, 2003 667 0 0 bradenton florida Apr 22, 2004 #1 Apr 22, 2004 #1 I installed a new tremec, i reused my aod speedo gear housing, and it is leaking out of it bad, Are the manual and auto ones different?? thank you..
tvmango New Member Oct 27, 2003 667 0 0 bradenton florida Apr 22, 2004 #2 Apr 22, 2004 #2 anybody know??
TC93 Well-Known Member Sep 11, 2000 2,075 1 57 Ellerslie GA 31807 Apr 22, 2004 #3 Apr 22, 2004 #3 When I swapped from Tremec to AOD, I used mine but swapped the gear and never had a problem. Might want to check the seal on the housing.
tvmango New Member Oct 27, 2003 667 0 0 bradenton florida Apr 22, 2004 #4 Apr 22, 2004 #4 cool, thank you,, tony
B blk92stangg New Member Jan 30, 2004 583 0 0 Hawaii Apr 24, 2004 #5 Apr 24, 2004 #5 Yeah, the aod speedo gear is longer than the t5 one. If you are reusing the same gear the thing won't seat properly. You can trim the aod one to fit, but I don't remember how much you need to cut. You could probably do it by trial and error.
Mustang5L5 That is…until I whipped out my Bissell Mod Dude Feb 18, 2001 43,365 18,109 224 Massachusetts Apr 24, 2004 #6 Apr 24, 2004 #6 SO on a AOD to T-5 swap, i can reuse the same screw and speedo housing? I know i need to change to a T-5 speedo gear.
tvmango New Member Oct 27, 2003 667 0 0 bradenton florida Apr 24, 2004 #7 Apr 24, 2004 #7 I put in a t-5 gear, i think the o ring didn't seal,, I just didn't know if it was different....
