It has been a long time since I made any updates on my stang, so here it goes...
Last summer, after an unfortunate incident with a turbo and some the stock NA rings, I did a rebuild. Later that fall, I started getting some piston slap when I started it in the mornings. that continued to get worse, but this spring, it developed a terrible knocking until it got completly hot. Looks like it needed to be bored over, but I didn't have the tools to check it, and my machinist didn't check it for me.
Fast forward to this summer. I bought a used engine from an 89 lx mustang so I could have a shortblock to build up and swap for convience. It had to be bored over, so I went .030 over with some diamond pistons. The crank was in spec, and I had everything balanced. I hope to have this engine in the car, and running by the end of the week.
The only change from before will be the LIGHTER diamond pistons, and slightly more compression from boring it over, and having the rotating assembly balanced. It will be interesting to see what kind of difference I see when I get it running again.
Here is my setup on the car:
Naturally aspired
dish pistons
Milled the head for 9.8:1 compression with the turbo pistons
long tube header
mild cam ([email protected], [email protected], .454lift 112lsa)
LB3 turbo computer with correct injectors and VAM
rebuilt A4ld
Before I pulled it appart, I was running mid 18's at 75mph. Obviously, the A4ld doesn't get me off the line very fast, and my 2.7X 60' times kill the quarter times.
PLANS FOR THE FUTURE: Hopefully, I will be able to port one of my spare heads, hang a turbo off it, and bolt it on.
Naturally aspired
dish pistons
long tube header
rebuilt A4ld
