i got comp xe270ah cams for my 2000 gt. can i get away without changing springs. if i do change them can i do it with the heads on. how hard is it.
Comp "recommends" the springs be done.
Interestingly, their page for those cams also reads "Always check piston to valve clearance as Ford used a variety of piston vendors & designs with these engines. Some combinations may require aftermarket pistons for clearance."
COMP Cams: Xtreme Energy™, XE270AH <BR> Excellent Torque, Better Low & Mid-Range Torque w/ Power
Never seen that before...
I don't imagine PTV would be a problem as long as the cams are degreed.
Yes, you can replace the springs in situ but it's a pain. I've got 262AHs and stock springs with no problems (yet...)
I had (still have) the 270's in my car naturally aspirated with both stock pistons, and then a 5cc dish diamond. I never had ptv issues. I had the cams properly degreed and used the 113 springs, now I have 125's. I did however have the cams installed in SVO heads which may offer some additional clearance, but I am not sure on that. They have been decked like 3 times so any additional clearance is probably gone.
In my experience with the Comp 270's this has happened more often than not.If the motor is stock chances are the intake valves will be into the pistons.
Good info to know on the SVO heads, thanks for the upgrade Nick.
