- Nov 28, 2006
- 172
- 0
- 0
Well I'm having this problem where under load (wot) the motor is breaking up. Very noticable power loss, popping, backfiring noises....It all started when I was Trying to get the idle just right. Now, it's also hanging at 2500rpms, then dropping down to normal (feels almost like an injector is sticking open??). I pulled the IAC motor plug, set the idle, and then disconnected the battery and let it sit over night. In the morning I fired it up and started driving, then connected the IAC motor. Then the problems started.
I tried lowering the fuel pressure to a low of 35psi vac disconnected. Seemed to like 37psi. Im using 30lb injectors, and a vortech (C&L) maf with adjustable sample tubes. I've tried clocking it many different ways and it seemed to help/lessen the wot problem. But then I thought is the MAF ignored by the computer at WOT? If so, that would be eliminated... The weather has been extra warm out and I thought maybe it's detonation, so I reduced the base timing from 16*BTDC to 14*BTDC. Didn't help. It's also running hotter than normal, 210*or so... I have a 180* thermo/electric fan and it's always run right at 180-185*...Does this sound like a bad TFI? At first it seemed intermitant, but now it's happening every time i step on it. Under 3000RPMS it's fine mostly...For all I know it's the original TFI unit, I never replaced it before. It's only $40 from Autozone of $45 for an Accell piece....ANY IDEAS??? It was running so very nice, linear smooth power up to 6000rpm, but now I'm hesitant to drive it, let alone enjoy the engine Any suggestions are appreciated!
PS.
The other concurent/related problem is that at steady throttle, the motor will occasionaly 'stumble' and cut out momentaraly. Seems like this could be due to the crappy MAF transfer? I was thinking of getting a granetelli MAF....
PS.
Most of the time they fail the way I said, but sometimes they do spit and sputter before taking a poop.
