High temp duct tape?
65and68Stang
148
Raleigh, NC
Hi guys,
Wasn't sure if this was technically "tech" or not, so I decided to post here.
Seems I have finally got my engine temps under control. Moved from electric fan to flex-fan with a shroud. The one issue I have is the shroud is not an exact fit (Griffin aluminum radiator) and there is a gap along the top and bottom where the shroud stands away 1/4" or so from the radiator, thus allowing air to be easily pulled in there as opposed to through the fins.
I put some duct tape over the gap today and it made a huge difference in the air being pulled through the radiator. Problem is that is got all shriveled and pulled away in spots after a 30 minute drive. I was wondering if there was a "high-temp" duct tape or some other product that would be good for application that someone could recommend?
Thanks!
Kelton
Regular Duct tape, :notnice:
Use heater tape, Its a thin alum foil tape.
plumbing supply or Hardware store.
If you can mold metal, the fold a thin strip of tin/alum,
over and 1/4 in length of flat bar stock.
This will give you a U shape.
Then cut to length and trim the fold over down to size, till it clips in place and use a couple of small screws to hold it on.
Just the voice's. :p
PB
Foil Tape. Find your favorite A/C repairman, and wangle a deal to get a few feet worth from him, he should have a roll in his van. Hell, a whole roll of that stuff is less than $10, look for an air conditioning supply house near your place. You'll find some pretty creative uses for this tape. Be warned. It is sticky!!!
