Grn92LX said:
11.045:1 on my builders calculator. Its all on my computer with the rest of the specs including bearing clearances, ring gaps, rod ratio ect
How about that, Keith did the same for me...piston, pin, locks, ring, rod weights (in grams), ring combination, gap at the top, second ring gap, main journal, bearing bore clearances, rod journal, endplay, side clearance, torque specs, deck height on each square, etc, etc...oh, and the better rod ratio is also wrote down
Oh and for those that have static and dynamic compression mixed up or doesn't know anything about it...this might help:
Static -
http://e30m3performance.com/myths/more_myths1/comp_ratio/comp_ratio.htm
Dynamic -
http://cochise.uia.net/pkelley2/DynamicCR.html
Simple terms...static compression is volume at bottom dead center/the top dead center's volume which is left in the combustion chamber, quench area under the head, head gasket, and the amount of piston cc (valve relief area)...
Dynamic compression starts when the intake valve goes to close, where "actual" compression starts...not at the bottom of the cylinders travel (BDC). When the intake valve goes towards the valve seat that is where the engine actually makes compression and goes back towards the top to make the "boom"
Cam timing effects this...
Detonation is still more likely to occur in a hot zone or heat soaked engine...of course you can make an engine that will detonate with cold air...LOL. Just keep upping it up...bigger is better right...
