Rick 91GT said:lol @ Mike
11:1 is about as high as I will usually go for an alum head street motor, even when you take all items in consideration it can be borderline. With some hot air temps or really cool good air you have to be careful that you do not detonate, timing is crucial. You can get into Dynamic compression, bleedig cylinder pressures off,etc to help explain it all but that is over most guys heads...
Depending on your pistons, heads you may only be able to acheive 10.x:1 compression or lower. What are the specs on the parts you are using. I have a very good comp calculator....
306
new stock block
new stock rods
new stock crank
afr 185s (spring/valve upgrade)
tfs stage 2 cam
tfs street heat intake
forged pistons (unsure of specs)
bbk 70mm tb
pro-m 75mm ma
24# injectors
190 pump
aeromotive fpr
mac shorties / free flowing exhaust
3.90 gear
i know cutting those pistons to allow for that cam will drop my comp some. along with a thick gasket and the alum heads.
tell me this- judging from my parts, how high can i go on my compression and still be SAFE to use pump gas. also , if i make say 10.5:1 and if i make 9.5:1.....how much power difference would be between the two? would power suffer?
thanks. really appreciate all the help
