My car is a 93 Coupe with a 351 swap. Team Z K member, Bilstein coilovers, MM CC plates, 245/45/17 fronts, power steering. Pretty much everything is new. Including poly bushings, front sway bars, end links ball joints, etc. When traveling over 70 mph, it seems a little bit squirrelly. Not horrible, but I can't say I'd want to push it to much faster and still feel confident about it staying planted. Can an alignment that is a bit off cause this? I did have an alignment done somewhat recently, but I then later adjusted my toe angles with the ghetto "string method". I was trying to get my new Momo steering wheel perfectly centered, and the only option was to adjust the toe angles to get the steering wheel perfectly aligned.
