QCStang said:Shelby = 1 dead Dan
I think I'd probably end up killing myself with anything more than 400hp. For an "almost" old guy, I like to press the pedal...![]()
Cobracanuck said:Mario, do you think i should get dynoed if i have an exhaust leak? do you think i am going to make it worse or warp the headers? or lose alot of power?
Im going to see if i can get someone to fix it tonight. I really want to go, but not if im just going to make things worse![]()
Cobracanuck said:im going to try to go tonight. As far as i can tell, the leak is on the passenger side header. It makes a crazy (fingernail tapping on metal)sound when i start the car, then keeps doing it on every bump, for at least 20 mins.
From what i heard in the 94-95 tech section, it mean header leak. Im not anything close to a mechanic so i dont know for sure how to fix it.
Cobracanuck said:well, i can drop by campbell tonight, and you can let me know what you think.
Ill see you guys tonight, what time?
Stangfreak95 said:Sill confused about what is happening to the stang...Clutch/tires
I just went for a ride on a normal day, far from being cold and the same chit is happening. I'm putting my slicks on right now as we speak and gonna try it out. I know I wont be spinning those in 4th or 5th gear.
Man, I hope its only the tires that are the problem..![]()
KDK1988GT said:I still think its gonna be the clutch.. doing the slipping
Stangfreak95 said:It is I guess. Still happening. Somebody experienced is hopefully gonna hop for a ride tonight in my stang so I can show it to someone..![]()
KDK1988GT said:Good luck with it.. I hope you get it figured out...
Your clutch seems like it is not fully grabbing... I wonder if a throw-out barring could be making it not release or grab all the way.. Do you hear any noises? Of it sticking?? Or something like that??
Clutch cable might be stretched, change it cheaper then a clutch..
Does your clutch petal feel normal ???
Well man good luck with it keep us informed.. after tonight
Try Me said:Hey Stangfreak, where are you getting your dyno done?
I really really want to but its useless with the clutch problem. Instead of me, my friend is taking his 92 coupe with some weird stroking kit (might be 364ci).
I'm very anxious to see the numbers he'll put down.
so the numbers werent right. 2nd and 3rd pulls were similar and he put down 391rwhp and 398rwtq.
mpcv2000 said:Mario !
I don't know your clutch set up but if you have a adjustable one make sure there is some free play on the pedal , don't bring the adjuster too far out , you will minimize the free play on the clutch pedal , putting pressure on the bearing , pushing the pressure plate itself. More it wears more we have to adjust it.
mpcv2000 said:All the above is fiction , I'm not in or involved in any street racing activities , this was only for entertainnement..![]()
