Horsepower Question
I was curious about the est hp I would have with adding the following so I can calculate the right injectors I need.
Adding
73 mm C&L calibrated for the size
70 mm TB
70 mm spacer
edelbrock performer intake
trickflow twisted wedge heads w/1.6 roller rockers
With those parts you would be somewhere in the 300 h.p. range + or - 25 h.p. You could still use the stock injectors with this combo. But I would go with at least a 24 lb/hr injector, or 30 lb/hr. My reason would be that it would give me room to grow, if later I were to add more h.p. Then at least I would not have to buy injectors again and a new or re-calibrated MAF.
24lb injectors would suffice with that combo but if you decide to build a 331 or 347 stroker later on or add forced induction, you could get bigger injectors and have their duty cycle reduced by a custom EEC tune. This will give you the fuelling you need now and have room to grow later.
I plan to add a supercharger with 8 lbs of boost with a cam but that will be down the road. Will the stock drivetrain handle that power or will I need to upgrade that as well. I will not be driving constantly at the track just a little flooring now and then onto the highway.
I would personally go find a set of 24 lb injectors. 24's will work fine even if you run a stroker. The amount of money you'll spend on the blower, a few extra bucks on new (injector and o-rings) would be minimal.
As for the tranny and such, 31 spline axles, and a TKO with the supporting parts should be good.
Or, built AOD, didn't see that you were auto. I'd go with a 3200 or something stall if you plan on making good hard passes at the strip, but still street worthy.
