hot or cold plug?
Autolite #25 is the stock heat range for E7 heads. Only if you are running forced induction or a power adder would I change the heat range to a colder plug. A higher number plug is hotter and a lower number plug is colder.
my plugs look like a light chocolate brown, they look like there burniing normal to mebut i was curious?
i had carbon build up that keep breaking off and smashing my old plugs, so i took those heads off and put a clean set of ported ones on. i just dont want the problem to reacure.the heads that i pulled off had 117,000 mi on them so the carbon was probably normal.
what should my fuel pressure be?
