how big on injectors
  • Thread starter Thread starter nick_94cobra
  • Start date Start date Sep 18, 2007
N
nick_94cobra
25
  • Sep 18, 2007
hey guys
i've got a 94 gt, 331 stroker, and i'm having pinging problems. running exclusively on 93 octane, 12* timing. i upgraded the fuel pump to a aeromotive 255lph unit, but i'm thinking i went small on the injectors. they are only 24's. should i step up to 30's? i'm also running autolite 3924's for plugs.
thanks for the help in advance
Shamus O'toole
18
Florida
Sep 18, 2007
  • Sep 18, 2007
Yes run 30's...
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Sep 18, 2007
  • Sep 18, 2007
not enough information.... what kind of heads/ intake/ cam? to be honest you probably need to go back down to 19's 24's are plenty big enough for any naturally aspirated 302 combo. they can support up to 400 hp. so NO you dont need to go bigger.
Flavadave4
1,044
21
49
Utica, NY
Sep 18, 2007
  • Sep 18, 2007
What's the compression ratio?
C
cjnecessary
70
richmond,in
Sep 19, 2007
  • Sep 19, 2007
I was getting ask how big on injectors for my combo I was thinking the 30lbers were a little to much. I just don't have any power up top. The search button is great.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Sep 19, 2007
  • Sep 19, 2007
Injector HP ratings: divide flow rating by.5 and multiply the result by the number of injectors. This uses a 100% duty cycle. These ratings are for naturally aspirated engines.
Example:
19/.5 = 38, 38 x 8 = 304 HP
24/.5 = 48, 48 x 8 = 384 HP
30/.5 = 60, 60 x 8 = 480 HP
The preferred duty cycle is about 85% maximum, so for a safety factor multiply the final figure times .85.
304 HP x .85 = 258 HP
385 HP x .85 = 326 HP
480 HP x .85 = 408 HP
Remember that the above ratings are at 39 PSI. Increasing the pressure will effectively increase the flow rating. Example: a 19 lb injector will flow 24 lbs at 63 PSI, and a 24 lb injector will flow 30 lbs at 63 PSI.
See http://users.erols.com/srweiss/ to get the calculators used in these examples.
Here's the duty cycle explanation. Duty cycle is how much of the time the intake is open the injectors are turned on. The 85% figure means that for 85% of the time the intake valve is open, the injectors are spraying. The idea is that you want some percentage of the duty cycle left over so that you have some room to grow the process.
If you are at 100% and you need more fuel, all you can do is turn up the fuel pressure. That means the whole fuel curve from idle to WOT is affected. Maybe you are already too rich at idle, and turning up the fuel pressure makes it worse. If you had some injector duty cycle left to play with, a custom tune could use that where it is needed. That would not over richen the whole range from idle to WOT.
N
nick_94cobra
25
  • Sep 19, 2007
it's a 331 stroker, edelbrock peformer rpm heads, rpm intake, ford racing f cam. 10.5 compression. it only seems to ping when i'm on it over half throttle above 3000 rpm. thanks for the help again.
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Sep 19, 2007
  • Sep 19, 2007
I doubt the pinging problem is due to the injectors.
Killercanary is running 24 lb injectors on a more aggressive setup than yours (more cubes/better heads/cam) at only 82% duty cycle.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Sep 19, 2007
  • Sep 19, 2007
I run 30's on my n/a pump gas 347 and they're near maxed out fwiw.
I don't think the injectors are your problem either.
samickguy15
404
Delavan, IL
Sep 19, 2007
#10
  • Sep 19, 2007
  • #10
I would look at timing. I suspect somewhere you are picking up too much timing when you're getting into it. Try backing your base down to 10° and go from there.
C
cjnecessary
70
richmond,in
Sep 20, 2007
#11
  • Sep 20, 2007
  • #11
Timing +1
Flavadave4
1,044
21
49
Utica, NY
Sep 20, 2007
#12
  • Sep 20, 2007
  • #12
Set the base timing at 10 degrees and the Fuel Pressure @ 38-40 psi with the vac line off. Add timing from there, back it off if you get and knock.
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
