My 91 GT has water spots on the sunroof. No matter how much elbow grease I use its not coming off. What do you all recommend?? Rubbing compund??
Most likely you wont have this but, what I do is take wheel acid on a cloth, and wipe it on the glass then wipe it off. So far it has worked every time. I've done it on around 40-50 cars![]()
I've been told you can use ultra fine steel wool on glass, though I've never tried it myself. Also, you can use the same wax that you use on your paint to wax the glass. Don't know if the wax will remove the spots, but it will stop any more from showing up.
The one thing I will say is that you have to be REALLY careful when using chemicals other than plain old auto glass cleaner. Some of the harsher cleaners will deteriorate rubber seals and damage paint.
heres my version of a gearbanger answer "just go buy a new car they have better glass on them"
but seriously did you try anything out?
