how do i convert my turbo coupe rearend to 5-lug...
^ I think you would have to use the ranger/aerostar 5 lug axles with those on a Mustang. Or they bored out the flange hole on the rotor for sn95 axles for use on a actual TC.
So if I wanted fox length axles with a TC rear I'd be stuck with the 9 hole rotor?:shrug:
I guess the sn95 axle/MVP rotors would work perfectly with a Cougar.
Why can't you use the Mazda rotor with the brackets you have? Are you afraid the center bore is too large on the Mazda rotor? Actually, those rotors are 7 hole and one slot :p
