alright mods i have are in my sig. short of doing coilovers, what suspension set up can i run that will help me keep up with these pesky little guys in the twisties??
joel
joel
With the mods you have, you should be killing them as it is?![]()
Try to lighten the car as much as possible. They have the ability to brake later and carry through the corner faster. Larger brakes will let you brake later... good rubber too. The KYB shocks aren't know for being the best but there are other areas you can improve first. A pan hard bar to tighten up the rear will give you some confidence in the corners. Relocating the battery to the trunk will effectively redistribute some more weight to the rear(which is greatly needed). As stated above some upgraded sway bars and replace the old tired... probably rotted rubber bushings. Stiffer springs may help but along with the shocks, there are other areas which can give you a better foundation to work and judge off of if needing replaceing. Short of coil overs and a 5 link... there are a few tricks but your biggest edge is your torque when you come out of a turn. Wider tires i forgot to mention before too.
Kevin
what tires are you running?? You gotta be able to plant that thing to the road or all the suspension parts in the world wont help. And then learn your cars limits and by all means don't push em. We don't want to see another thread " Wrecked my stang while racing a civic"!!
You should be able to rip the civic easily especially with those being fwd they will push alot generally when coming out of the curve if they accelerate to early unlike your car you just might need a little countersteer
