How do I tell if i have a 5.0 h.o. motor
  • Thread starter Thread starter mustangdude67
  • Start date Start date Jun 17, 2007
M
mustangdude67
  • Jun 17, 2007
I received a free complete 302 motor but without the upper half of the intake. I am changing it over to a carbed setup for my 67 mustang. While takeing off the lower intake manifold I noticed it had a plate going to the rollers. long thin plate about a half of an inch and tabs going off to each lifter. I noticed in a catalogue that this was a retainer plate for a roller cam. Does this mean I have an h.o. motor, or a non h.o. motor with a roller cam or a non h.o. motor. The motor is stock from the factory and has not been opened besides me. The reason i am asking is because of the firing ordear i should use. The one time i ran it with a regular 15426378 firing ordear it sounded realy crapy. Also is there any other ways to tell if I have an h.o. motor. Any help would be great. Thanks
Mr. Rustypwnz
Advanced Member
Jun 1, 2005
1,761
63
69
indianapolis/ valdosta ga
Jun 17, 2007
  • Jun 17, 2007
the h.o firing order is 137---48 cant remember the rest, but I might not be a h.o. i really dont think it would have even ran with a different firing order.
vristang
4,933
101
124
Seattle
Jun 17, 2007
  • Jun 17, 2007
Check the firing order at the cam/rocker arms...
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Jun 17, 2007
  • Jun 17, 2007
This doesn’t prove that the block is HO. Some trucks evidently use a HO firing order
with a low lift cam. However, it will definitely prove that a block can’t be HO because the firing order is wrong.
Remove the #1 & #3 spark plugs. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Slowly turn the engine until the TDC mark and the timing pointer line up. Mark TDC on the balancer with chalk or paint. Put your finger in #3 spark plug hole and crank the engine 90 degrees. You should feel pressure trying to blow past your finger. If you do not feel pressure, repeat the process again. If you feel pressure, it is a HO engine.
No pressure the second time, remove spark plug #5. Put your finger in #1 spark plug hole. Crank the engine over until you feel compression on #1 cylinder. Put your finger in #5 spark plug hole and crank the engine 90 degrees. If you feel pressure now, the engine is not a HO model, no matter what it says on the engine.
Using a small carpenter or machinist square to mark the harmonic balancer off into 90 degree sections may be helpful here.
A 15/16 deep socket & breaker bar or ratchet may be used to turn the engine.
The HO firing order is 1-3-7-2-6-5-4-8.
Non HO firing order is 1-5-4-2-6-3-7-8
M
mustangdude67
  • Jun 17, 2007
thanks for the help
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Engine help identify what 5.0 i have. H.O?
  • snackman508
  • Jul 16, 2021
Fox 5.0 Mustang Tech Jul 18, 2021
snackman508
Engine adjust roller rockers on new 393
  • maxine-70
  • Dec 27, 2023
3K
Fox 5.0 Mustang Tech Dec 30, 2023
AeroCoupe
Engine Roller Rocker to Valve Retainer Interference - Possible Source of Valve Train Noise
  • AeroCoupe
  • May 22, 2023
2K
Fox 5.0 Mustang Tech May 28, 2023
AeroCoupe
