  • SN95 4.6L Mustang Tech
how do you replace turn signal bulb?
  • Thread starter Thread starter adversary
  • Start date Start date Nov 24, 2007
adversary
448
titusville, fl
Nov 24, 2007
  • Nov 24, 2007
ok i have a 96 cobra (just got it) and one of the turn signals has a clear bulb in it i want to change it to yellow. How do you get the bulb out? The back of it is in the wheel well. and if you have pictures that would make my life so much easier right now! Thanks.
It's a little different from my 91' notch
DTNODYA
831
  • Nov 24, 2007
Pop the hood, look down at the headlight. To the right you will see a single nut that holds on the corner lamp. Remove the nut, the corner lamp assy will just slide out. I find it easiest to use a 1/4in. ratchet with a small extension to remove the nut but some wrenches work fine. Remove the plug going into the bulb (pry out lightly on the little tabs to release, they break easily, or at least mine did .. It'll still work if you break em though .. FWIW).
Then turn the bulb and remove it from the assy. Install new bulb and use reverse instructions to install.
adversary
448
titusville, fl
Nov 24, 2007
  • Nov 24, 2007
thanks, i tried that before i posted this and the light would not slide out. I was going to get a screwdriver and try to pry it out but i thought maybe there were more screws/nuts holding in from the back.
so it's just the one screw that holds the assembly in there?
thanks again
Twista
510
@ the z00 in chicago
Nov 24, 2007
  • Nov 24, 2007
^ Yep, just one nut holding it on. Its fine to pry it away because sometimes mine get stuck with my aftermarket lights.
Its pretty easy.
DTNODYA
831
  • Nov 24, 2007
It's only the one bolt/nut, yep. But there are 3 (if I remember correctly) little plastic dowels(?) that have to slide into place. When you take the nut off, try pushing on the bolt sticking out. If that won't budge it, then take a screwdriver and put a cloth over it (something soft) and pry each edge of it lightly .. It's probably because its cold that is making it stick.
blackfang
1,290
Richmond, Va
Nov 25, 2007
  • Nov 25, 2007
I replied in the SVT section last night. Simple as pie.
1992 2.3LX
885
Ky
Nov 25, 2007
  • Nov 25, 2007
adversary
448
titusville, fl
Nov 25, 2007
  • Nov 25, 2007
got it guys thanks i took the intimater to it. aka hammer to the one bolt and it popped right out.
i just wanted to make sure before i took the hammer to it that there was no hidden bolts in the back - that would have sucked to hit it then.
one more question where is the cheapest place to get smoke headlights? all of them including fogs.
J
Electrical Cluster bulb LED swap gauges bounce
  • jpfox
  • Jun 29, 2025
Fox 5.0 Mustang Tech Jun 29, 2025
gkomo
70 Mach 1 Turn Signal Indicator light issue,
  • 70 Mach
  • Oct 19, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
Mach1 Driver
M
68 horn and turn signals stopped working
  • connella08
  • Sep 10, 2025
Classic Mustang Specific Tech Sep 10, 2025
Z
Turn signals not working at all, but hazards do. 91 fox LX 5.0
  • Zeke1995
  • Jun 22, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 12, 2025
Jarhead67
J
D
Turn signals work only with ignition on & Engine off.
  • DienstXIV
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 7, 2025
DienstXIV
D
