how do you replace turn signal bulb?
adversary
448
titusville, fl
ok i have a 96 cobra (just got it) and one of the turn signals has a clear bulb in it i want to change it to yellow. How do you get the bulb out? The back of it is in the wheel well. and if you have pictures that would make my life so much easier right now! Thanks.
It's a little different from my 91' notch
Open the hood. On the underside of the fender where that light is(you can gain access from up top), is a nut. Take that nut off(I think it is a 12 or 13 mm). Once you do that, you can pull out the side marker light. Then you can remove the bulb and install a new one.
To install marker light, repeat same steps in reverse.
