How far can i push the stock 302?
  • Thread starter Thread starter dubbsix
  • Start date Start date Oct 29, 2006
First Prev 2 of 2
90_Red_LX
668
Asheboro, NC
Oct 30, 2006
#21
  • Oct 30, 2006
  • #21
GT40 crap won't feed a stroker like a AFR, TFS or canfield head will. If you go big with cubes go bigger with parts. GT40 stuff is good on a budget 302 build, but better parts will still make more power on a 302. It will really choke a 347, and it'll be a complete waste.
mustang217
RI
Oct 30, 2006
#22
  • Oct 30, 2006
  • #22
I was really surprised when the GT40 intake on my car was able to feed enough power to make 611 at the wheels. I know I could easily hit 650-680 at the wheels with pushing the tune a little more. Everyone seems to think iron heads suck but I also have a set of ported Dart heads which...guess what....are iron. The point is that you can make horsepower even with stuff that everyone else considers crap....LOL
mob
the guy who hits on his mom
20+ Year Stangneter
Oct 3, 2003
2,566
136
104
Dallas, TX
Oct 30, 2006
#23
  • Oct 30, 2006
  • #23
Modular2v said:
the material the head is made out of has nothing to do with the way the head performs. . . the weight difference is the reason why aluminum is better. A victor jr head would provide the same gains wheather it was cast iron or aluminum
Didnt mean to say that, just meant to say a Aluminum heads, such as AFR, and TFS flow alot better then a factory gt40p head, whitch are iron.
dubbsix
347
Katy,TX
Oct 31, 2006
#24
  • Oct 31, 2006
  • #24
Sounds like the truth is that it depends on how you put these parts together. A system approach rather than just throwing a bunch of unmatched parts on the motor.
rd
3,316
63
109
Ocean Springs MS
Oct 31, 2006
#25
  • Oct 31, 2006
  • #25
The advice to figure out a combo that you will keep for a while and going with it is the best out there. There is usually a lot to be gained from tuning, etc.
I was really pleased when my 82 cracked the 12's, with it 18 year old shortblock and iron Gt40 heads. But I actually gained the last second of et with tires, torque converter and rear suspension stuff.
I have tried the approach of buying parts and then having to upgrade something else to get them to work, and it costs a lot more in the long run.
I have had two complete carb and intake setups, two complete exhausts, etc, and all the expenses of changing, etc. It's on its 3rd set of heads, and each of the last two sets took about $5-700 for parts and machine work to install, and I still use bolt down stock rockers, etc.
I would be $1500 ahead if I had not played around, but, maybe thats just the price of this fun...
dubbsix
347
Katy,TX
Oct 31, 2006
#26
  • Oct 31, 2006
  • #26
Very good advice.
87'GTstang
1,025
#27
  • Nov 1, 2006
  • #27
That has always been the name of the game. You have to put parts together that work together.
seijirou
2,417
DFW
Nov 1, 2006
#28
  • Nov 1, 2006
  • #28
If you want to play around with your 302 now, do it budget, gt40ps, exploder intake and tb, etc. etc. You can give yourself another 100 horse for less than a grand and have some fun.
For the "real" build it really depends on what you're looking for. If you want more than 400rwhp not running on borrowed time you really should look into a 351-based build. If only because it's a gamble to make that much aon a 302 to the rear. Some crack right away, some don't, but you don't know. You'll have much better chances with the 351. You can even leave the rotating assembly alone, still have more than 347 cubes, and all the other upgrades are just like a 302.
L
li'l Notch
#29
  • Nov 1, 2006
  • #29
try the trick flow engine kit it comes with every thing u need its a basic hci(heads,cam,intake,) thats all u really need to be a bad stang out in the streets:SNSign:
L
li'l Notch
#30
  • Nov 1, 2006
  • #30
Long live notchbacks
dubbsix
347
Katy,TX
Nov 12, 2006
#31
  • Nov 12, 2006
  • #31
seijirou,
I am new, but do you have any info on a 351 install into a fox body? I know they bolt right in, but what about intakes and fuel rails?
seijirou
2,417
DFW
Nov 13, 2006
#32
  • Nov 13, 2006
  • #32
You can use your 302 fuel rails, however you will need to replace the hoses that join them together with some longer ones. You can get high pressure fuel injection hose at Autozone and such. Similarly the lower intake manifold for a 351 also needs to be wider. You can get a typhoon 351 upper and lower intake pretty cheap for a fuel injected setup. It's a knockoff of one of the Edelbrock variants. There is also the Gt40, and a few others but I'm not sure which they are off the top of my head.
There are a few guys on here that have great writeups about 351 swaps. If I can find one before one of those gentlemen finds this thread I'll post up the link.
seijirou
2,417
DFW
Nov 13, 2006
#33
  • Nov 13, 2006
  • #33
Okay, it's Vristang that has the nice website with alot of information on the subject, aswell as alot of other subjects aswell.
The website is http://www.freewebs.com/vristang/ and I highly recommend checking it out. If you use that URL, look to the right and you'll see the link, "Fox 351w Swap FAQ". Which answers almost every question you could come up with.
First Prev 2 of 2
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
Engine 1990 LX 5.0L EFI Mustang Fuel Management Problems - HELP!
  • 5.0LXStanger
  • May 25, 2025
  • 2 3
2K
Fox 5.0 Mustang Tech Jul 11, 2025
5.0LXStanger
T
Forced Induction On3 turbo on stock 89 with 87K miles --suggestions
  • tank76
  • Aug 2, 2023
8K
Fox 5.0 Mustang Tech Aug 27, 2024
AeroCoupe
