How fast is my car?
  • Thread starter Thread starter rhyrlik
  • Start date Start date Jul 19, 2009
  • 3
First Prev 2 of 3 Next Last
squeak93
2,357
419
164
Joplin, Missouri
Jul 21, 2009
#21
  • Jul 21, 2009
  • #21
rhyrlik said:
I realize that, however I'm asking in a generally speaking kind of way, not necessarily the ideal scenario. Kinda like my car vs a 97 Camaro.
That sir, is Bench racing....
Idealy, a blown 4.6 WOULD rape a lt1 camaro.... But there are a million factors here... Mods on the camaro, driver skill for each car, tires they are on.......
blubullett
535
Modesto, CA
Jul 21, 2009
#22
  • Jul 21, 2009
  • #22
I pass smog in CA with my stock h-pipe swapped back on. Just did it a couple weeks ago and all my numbers were in the single digets, bottom 5% of the allowable emmissions. It was cleaner then chit. You need a custom tune or something. There has got to be another 50hp in that thing. With nothing but the procharger I was 380/405. With completely stock exhaust and no powerpipe.
R
rhyrlik
125
#23
  • Jul 22, 2009
  • #23
That's interesting. When I was at Powertrain Dynamics getting dynotuned, the most he could squeeze out oif her was 307 RWHP before she started detonating. I heard that some of the 2002 motors had high compression. Is yours a 9:1?
R
rhyrlik
125
#24
  • Jul 22, 2009
  • #24
Bench Racing is all I can do right now.
Winters98GT
Whoop...whoop-whoop-whoop-whoop...GANGNAM STYLE!!!
1,291
224
H Town
Jul 22, 2009
#25
  • Jul 22, 2009
  • #25
Then don't talk about your car in a race or what it can beat, get beat by, or keep up with. It's simple.
R
rhyrlik
125
#26
  • Jul 22, 2009
  • #26
I'm not talking. I'm asking. Know the difference?
Winters98GT
1,291
224
H Town
Jul 22, 2009
#27
  • Jul 22, 2009
  • #27
You just don't get it . Nobody knows how fast your car is, because you won't run it. Take it to the track for 15-20 bucks and answer your own question.
As I stated, and others have, you are bench racing, asking a question about how fast your car is or
is nonsense, line them up at a track and find out.
You obviously started this thread because you are "talking", not "asking" other people in your area or other forums about your car. So you, Sir, are bench racing. Asking, is bench racing, because we don't know. 300rwhp can be good for 11's with the right setup and driver, or 14's.
R
rhyrlik
125
#28
  • Jul 22, 2009
  • #28
I disclosed my setup.
Everyone but you assumed competent driving.
Why can't I ask this question?
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Jul 22, 2009
#29
  • Jul 22, 2009
  • #29
Too many factors..
could run anywhere from 12's with slicks and skinnys and a decent driver to 99.999999999 <--- ET equivalent of infinity
In my opinion until you run it on the track it runs 99.9999
You should make some time to try and get to a track for one it's a lot of fun... two you will learn a lot about how to drive your car
R
rhyrlik
125
#30
  • Jul 22, 2009
  • #30
Does CA Speedway allow the general public to drag race?
Mike97gt
it doe snot
10,633
Jul 22, 2009
#31
  • Jul 22, 2009
  • #31
I am not sure what tracks are near you.. if you search in google you should be able to find the websites for any that are
R
ran260gt
365
#32
  • Jul 22, 2009
  • #32
Some of you guy are being Dicks , rhyrlik gave his mods and HP level , so based off of Mustangs seen at the track with similar mods or HP , you or I can give a ball park E/T !
Everybody I go to the track with does the same thing , we look at cars and make a guess before they run , this is no different just because you cant see his car !
If its a low track and he can hook , he has a 12sec car , whats so hard about saying that !
blackfang
1,290
Richmond, Va
Jul 22, 2009
#33
  • Jul 22, 2009
  • #33
High 13's.
Until you line it up, you are wasting time, or afraid of the real time it may be.
Stan Weiss
347
Philadelphia, PA
Jul 22, 2009
#34
  • Jul 22, 2009
  • #34
We do What do we have to base that on?
It has been answered. The only way to know for sure is to take it to the track. Based on a HP and torque number the best that can be done is a guess. Does this dyno read high does this dyno read low. Are these corrected numbers and if so to which SAE standard? Posting the dyno sheet would help a little.
blubullett
535
Modesto, CA
Jul 22, 2009
#35
  • Jul 22, 2009
  • #35
I am 100% sure that all 2v mustang motors produced between 1999 and 2004 had the same compression. On Kenne Bells websit it says that the 6psi kit should be worth 106 hp more then stock. That should put you closer to 340 I would think. Maybe you were running out of fuel causing it to detonate. What injectors and pump are you running? If it is the stock with the Boost-a-pump maybe your stock pump is going out. I would get a svt focus or ford GT pump and put the boost-a-pump away till you need even more fuel. Did they data log anything when it was on the dyno?
I bet you would run in the twelves somewhere. It is really hard to tell untill you actually go to the track. It takes practice to run a consistant time. One run might be a 12.4 the next a 12.9. If anyone asks just tell them it a twelve second car.
Im not sure about drag strips around you. I know in Sacramento they let you run for 10 bucks every wed. and 50 bucks every other friday. It is worth it to pay the 50 for friday cause no one is ever there so you can get more runs in. And you ususlly don't have to even wait for more the one or two other cars to run. There must be something like that down south.
Bench racing is fun guys. I bet all you loosers do it all the time with your buddies. Stop with all the BS and just say what you think it will run, yes there are variables but what do you think it will run with you driving it? I know anything I drive will run 9s for sure
Gearbanger 101
Straight Outta Locash
20+ Year Stangneter
Aug 10, 2002
9,457
1,377
234
Ontario, Canada
Jul 22, 2009
#36
  • Jul 22, 2009
  • #36
The last thing anyone needs to do is put stock on what Kenne Bell numbers tell people what their cars "should" be making. Rarely have I seen Kenne Bell cars meet advertised claims...and when they do, there are usually other deciding factors involved. They dyno test their cars with excessive amounts of timing and in many cases with race gas in the tank.
Consider Kenne Bell figures a best case scenario, not a real world expectation.
FYI, most Kenne Bell '99-'04 cars I've seen/heard running around are putting down between 290-320rwhp@6psi (depending on the drive line) with few, or no other bolt ons to speak of. And that's running the available 91-94 Octane pump gas. Those are numbers you can realistically expect.
98COBRA281
1,348
30
59
Port St. Lucie, Florida
Jul 22, 2009
#37
  • Jul 22, 2009
  • #37
300rwhp is usually good for 12.70-12.80's, thats about what my car makes, but my best time so far is a 13.31, so my car is a low 13 sec car, not a 12 second car YET...
R
ran260gt
365
#38
  • Jul 22, 2009
  • #38
Are you runing a stock tire , 60` 2.1 with a 108 trap , sounds like some slippery racing through the first 330 mark !
Winters98GT
1,291
224
H Town
Jul 22, 2009
#39
  • Jul 22, 2009
  • #39
2 great replies.
So people run 11's out of the factory in my car, with stock tires. Do I have an 11 second car? Nope. It's simple, you can't claim you have an 11, 12, or 13 second car until you run it.
R
rhyrlik
125
#40
  • Jul 23, 2009
  • #40
OK, then let's rephrase the question:
Given my setup, what have similar setups yielded on the track?
For example, plenty of stock 1999-2004 GT's have ran 14.0 second quarter miles. How about those with my setup? I can't be all that unique.
  • 3
How Many Runs For A Built C-4
  • 93gtmustang
  • Apr 19, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 15, 2025
revhead347
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
SOLD SOLD!!!! 1993 Notchback Roadracer For Sale. She's a beast!
  • Boydster
  • Apr 25, 2025
Fox Body Mustangs For Sale (1979-93) Apr 25, 2025
Boydster
  • D Durden
  • Oct 20, 2025
  • 2 3
4K
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
