The rear suspension in the 79-04 cars is definitely a case lesson on engineering compromise.
The uppers aren't solely responsible for locating the rear axle laterally: They must act along with the LCAs to generate the required triangulation to locate the axle under the car.
Similarly, the lowers aren't solely responsible for sending thrust into the chassis: The uppers and lowers both react to torque inputs (i.e. axle wind-up from both braking and accelerating forces.) Anyone who's ripped out their upper torque boxes know this. Without one or the other, the axle would obviously move sideways and/or back and forth or rotationally to an unacceptable degree.
Ideally the arms move in arcs in a single plane. But these arcs are no parallel to one another. If you start with both uppers at a given angle and measure the distance between their ends, then pivot them 20o and re-measure, you'll find the distance has changed. Ditto the LCAs. Now think about those ends: They are affixed at both ends to what amount to rigid bodies. The rear axle isn't going to deform and neither are the chassis mounts. For that matter, the arms themselves aren't going to give (at least much) either. This is what the bushings are for and it's why, for instance, from the factory the LCA fronts are elongated and squishy.
This "give" is responsible for the need for "quad shocks" which dampen the fore-aft movement of the axle allowed by those soft front bushings. It also results in a rear axle that's not all that well located. Lateral movement of the axle under the car can exceed a full inch under load, not exactly European sports car geometry...
But the give is also import to relieve some of the stress from the torque boxes. If you go super-stiff all the way around you've essentially solidified the rear axle and greatly increased the stress loads into the torque boxes. The bottoms are pretty robust but the uppers are, comparatively speaking, not. Lots of miles or harsh abuse can fatigue this metal and result in cracks forming in the brackets.
For this reason I tend to agree with bhuff: Don't try to stiffen everything in this ****ty design to the point you bind it up and risk the mounting point health. If you really, absolutely need a solid rear end then covert to a 3-link with a panhard bar (e.g. like the S197 cars) or, better, consider a torque arm arrangement which uses LCAs, a long torque arm and a panhard bar.
