Engine How many amps does a Mercury Villager fan pull?
boostfrk
712
69
59
Colorado
I picked up one of these in the JY a few months back and am hoping to install after the New Year.
Anyone know how many amps these pull on the high speed? I'm planning to pick up a Flex-a-lite VSC from Summit but want to make sure I get one that can handle the fan.
The impedence may not be the same as the resistance. But it is a good place to start. The newest Street Rodder magazine had an electronics article. The article's guide is 1 amp per inch of fan with 2 TIMES THE amps for start up. Add a little extra for safety in your relay. (edited for stupid phhone errors!)
I'll let you read and decide the author's intent - I think yes, the article does cover your spike with 2x the amps.
Pg 92, top of second column of the March 2013 Street Rodder magazine. (It has a red '32 with a supercharged W motor on the cover)
" ELECTRIC FANS
On average, an electric fan will require 1 amp per inch of overall diameter to operate at normal speed. For instance a 12-inch fan will require 12 amps to operate but also note that twice the amperage is required duing initial start up. Be sure the circuit protection can handle the start-up load as well as the fan relay."
Reactions: gearheadboy
